NI TestStand
Is there an easy way to synchronize multiple computers running teststand?
I have a test setup where I need to have teststand running on two seperate comupters, but the sequences need to be in sync with each other so that the correct steps happen in the right order.  I was hoping to do this over ethernet if possible.
Thanks in advance for your help.
(3,073 Views)
Accepted by RawlingsSc
There is a way to access synchronization objects remotely with TestStand.  Look at Appendix B, Synchronization Step Types, section called 'Setting Up TestStand for Accessing Synchronization Objects Remotely' of the TestStand Reference Manual.
link to the ref manual: https://www.ni.com/docs/en-US/bundle/373435e/resource/373435e.pdf
Jim
(3,060 Views)
