NI TestStand
Is there a way to run a search/edit on all steps within a sequence?
Is there a way to apply an search/edit to all steps within a sequence.  For instance, if you wanted all instances of "27_" to change to "59_", is that possible in TestStand 4.2.1?
(3,136 Views)
Accepted by mcfrenzy36
Did you try hitting "Ctrl" + "F" on your keyboard?  That is what I use all the time and you can Find/Replace with it.
(3,135 Views)
