Insert SubSequence Call Step using TS API
We are creating a LabVIEW application that generates TestStand Test Sequences, using the TS API.  I am attempting to write a SubVI that creates a TestStand Sub Sequence Call step.  The problem I am having is that although I can create the SubSequence call without problem I cannot seem to find a way of specifying the arguments for the parameters to pass to the sub sequence that is called by the SubSequence call step.
We are using TS 3.1 and LV 7.1
Has anyone got any ideas?
Regards
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
(7,098 Views)
Hi Steve,
I have done this with C# take a look to this code
static bool DoSequenceCallStep( XmlNode nodeStep, Step step, SequenceFile seqFile, Engine engine)
XmlAttributeCollection attrColl;
attrColl = nodeStep.Attributes;
XmlAttribute attrID = (XmlAttribute)attrColl.GetNamedItem("ID");
XmlAttribute attrName = (XmlAttribute)attrColl.GetNamedItem("Name");
XmlAttribute attrMin = (XmlAttribute)attrColl.GetNamedItem("Min");
XmlAttribute attrSoll = (XmlAttribute)attrColl.GetNamedItem("Soll");
XmlAttribute attrMax = (XmlAttribute)attrColl.GetNamedItem("Max");
XmlAttribute attrDoReport = (XmlAttribute)attrColl.GetNamedItem("DoReport");
XmlAttribute attrSeqName = (XmlAttribute)attrColl.GetNamedItem("SeqName");
String strSeqName = attrSeqName.Value;
Sequence sequence;
// sequenz neu erstellen falls sie noch nicht existiert
if (!seqFile.SequenceNameExists(strSeqName))
sequence = engine.NewSequence();
sequence.Name = attrSeqName.Value;
PropertyObject pObj = sequence.Parameters;
pObj.NewSubProperty("dblMin", PropertyValueTypes.PropValType_Number, false, "", 0);
"dblSoll", PropertyValueTypes.PropValType_Number, false, "", 0);
pObj.NewSubProperty("dblMax", PropertyValueTypes.PropValType_Number, false, "", 0);
seqFile.InsertSequence(sequence);
else
sequence = seqFile.GetSequenceByName(strSeqName);
SequenceCallModule objModule = (SequenceCallModule)step.Module;
objModule.UseCurrentFile =
true;
objModule.SequenceName = strSeqName;
objModule.UseSequenceParameterPrototype =
false;
objModule.LoadParametersFromSequence(sequence);
SequenceCallParameters Parameters = objModule.Parameters;
SequenceCallParameter Parameter;
String strValueExpr;
Parameter = Parameters[0];
if (attrMin.Value.Length == 0)
Parameter.UseDefaultValue =
true;
else
strValueExpr = attrMin.Value.Replace(
Parameter.ValueExpr = strValueExpr;
Parameter = Parameters[1];
if (attrSoll.Value.Length == 0)
true;
else
strValueExpr = attrSoll.Value.Replace(
Parameter = Parameters[2];
if (attrMax.Value.Length == 0)
true;
else
strValueExpr = attrMax.Value.Replace(",", ".");
// Do Report
bool bDoReport = true;
if (attrDoReport.Value.Length != 0)
String strHelp = attrDoReport.Value;
if(strHelp.CompareTo("0") == 0)
bDoReport =
false;
else
bDoReport =
true;
step.RecordResult = bDoReport;
// SeqName
step.Name = attrName.Value;
return true;
Do not care about the XML stuff from the i get the values !
I think this code snipped could be useful your you because the procedure in LV is the same
Greetings from the lake of Constance, Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(7,075 Views)
Cheers Juergen
Exactly what I needed.
Regards
Steve
(7,070 Views)
Hi Juergen,
What is the namespace that I need to include for the code in C# for calling the TS APIs to add new sequences in TestStand 4.0 dynamically?
Saranya.
(7,032 Views)
Hi Saranya,
Good question, you have to implement a second component the AdapterApi.
1. Component: (In German Called: Verweis)
NationalInstruments.TestStand.Interop.API
Location: C:\WINDOWS\assembly\GAC_MSIL\NationalInstruments.TestStand.Interop.API\4.0.0.326__ad9244eb3b825cd8\NationalInstruments.TestStand.Interop.API.dll
2. Component:
NationalInstruments.TestStand.Interop.AdapterAPI
Location: C:\WINDOWS\assembly\GAC_MSIL\NationalInstruments.TestStand.Interop.AdapterAPI\4.0.0.326__ad9244eb3b825cd8\NationalInstruments.TestStand.Interop.AdapterAPI.dll
Juergen
--Signature--
(7,029 Views)
Hi, is there a way to do that  using C++ language?
Thank you for  your help
(5,420 Views)
How to do this using Labview.
I have inserted parameter into the TS.SData.ActualArgs.
But I am getting error in the module tab.
17500
Error Occured while trying to refresh edit panel SeqEdit.o
operation Failed.
(Continuous error pop up.have to close editor)
But I can see that parameter inserted in the TS.SData.ActualArgs.
Bharath
Thanks & Regards,
Bharath Kumar
GCentral
(4,356 Views)
