04-19-2022 10:17 PM
There is a TestStand example name "Building a Sequence Using API - XML.seq". But the example is too simple. How to create a step calling LabVIEW vi? It's better if share some help files.
04-20-2022 01:20 AM
Hi 001,
maybe this thread contains what you're looking for
https://forums.ni.com/t5/NI-TestStand/Create-a-LabVIEW-Step-dynamically/td-p/976702?profile.language...
Best regards
Juergen
04-21-2022 09:42 PM
Hi j_dodek,
It's different. I want to generate a XML or INI file. Then Run a teststand sequence which can analysis the file and execute.
04-22-2022 02:29 AM
did you open the CreateSeqFileReZIP.zip ?
Best regards
Juergen
