NI TestStand
How to specify environment when using custom interface
Hi
this thread is almost dealing with my task.
https://forums.ni.com/t5/NI-TestStand/How-to-specify-environment-when-using-custom-OI/m-p/3617452
BTW my task is quite different. I am NOT using the ApplicationManager. So commandline will not work at all.
I am initializing the engine in old school:
HRESULT res = m_engine.CreateInstance("TestStand.Engine");
is there any change to work with environments?
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,256 Views)
Hey Juergen,
It looks like you can call EngineInitializationSettings.SetEnvironmentPath() before creating the engine. The EngineInitializationSettings class is new to 2016.
I haven't had a chance to try it... so let me know if that works!
-Trent
https://www.linkedin.com/in/trentweaver
(5,225 Views)
Hi Trent,
Thanks for this useful information.
Now I have the problem to invoke that class.
under TS2016 there is no CLSID.
#import "C:\\Program Files (x86)\\National Instruments\\TestStand 2016\Bin\\teapi.dll"
(at least did not found one)
How do you create that instance.
IEngineInitializationSettingsPtr engineInitSettings;
HRESULT res = engineInitSettings.CreateInstance(??????);
Or is  it provided by another interface?
Best regards
Juergen
--Signature--
(5,211 Views)
Accepted by topic author j_dodek
You should be able to get it with __uuidof(TS::EngineInitializationSettings).
Here's a crude snippet that i used to test:
Spoiler
#import "teapi.dll"
#include <iostream>
using namespace TS;
int main() {
CoInitialize(NULL);
IEnginePtr enginePtr;
HRESULT HR;
//Set Environment
HR = engineInitSettings.CreateInstance(__uuidof(EngineInitializationSettings));
engineInitSettings->SetEnvironmentPath("C:\\Users\\Public\\Documents\\National Instruments\\Custom\\myCustomEnv.tsenv");
//Get Environment
HR = enginePtr.CreateInstance(__uuidof(Engine));
std::cout << enginePtr->GetEnvironmentPath();
return 0;
I also have the include path added to my project settings instead of specifying it manually:
-Trent
(5,204 Views)
Hi Trent,
awesome!
More than a decade I was always using the CLSID.
and sometimes you would not see the simple life.
Thanks for opening my eyes
Juergen
--Signature--
(5,190 Views)
