NI TestStand
How to show/hide a step in the report on the fly?
I want to show/hide a step (example the built-in Wait) in the report based on a condition.  Is that possible?
In the report, it looks like:
Wait        Done
George Zou
(2,349 Views)
1. I think you can add a condition in PostResult engine callback.
2. It is possible to change result recording step property programmatically but I think it will alter sequence file as well (not only in run-time because it is shared AFAIK).
3. You can use result plug-in filters.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,318 Views)
Thanks, but how do I remove a step in SequenceFilePostResults ?
George Zou
(2,303 Views)
Accepted by topic author zou
Try Parameters.DiscardResult in SequenceFilePostResultListEntry.
Michał Bieńkowski
CLA, CTA, CPI
(2,297 Views)
