How to show/hide a step in the report on the fly?
I want to show/hide a step (example the built-in Wait) in the report based on a condition.  Is that possible?
In the report, it looks like:
Wait        Done
George Zou
(2,332 Views)
1. I think you can add a condition in PostResult engine callback.
2. It is possible to change result recording step property programmatically but I think it will alter sequence file as well (not only in run-time because it is shared AFAIK).
3. You can use result plug-in filters.
Michał Bieńkowski
CLA, CTA, CPI
(2,301 Views)
Thanks, but how do I remove a step in SequenceFilePostResults ?
George Zou
(2,286 Views)
Accepted by zou
Try Parameters.DiscardResult in SequenceFilePostResultListEntry.
Michał Bieńkowski
CLA, CTA, CPI
(2,280 Views)
