NI TestStand
How to set default sequence file path in C# VS
When try to set default seq file path as below, I got an error, can not Implicit conversion string to “NationalInstruments.TestStand.Interop.API.SequenceFile”
axSequenceFileViewMgr.SequenceFile = @"D:\test.seq";
Thanks for your help in advanced!
(3,823 Views)
I try to modify the code like below.
axSequenceFileViewMgr.SequenceFile.Path = @"D:\test.seq";
No error found when Compiled,but it still report wrong object call when running.
(3,819 Views)
Accepted by topic author TabZhang
Let me answer it myself.
axApplicationMgr.OpenSequenceFile(@"test.seq");
(3,806 Views)
