How to separate test results to folders according to date?
Is it possible to separate test results to folders according to date using Configure->Report Options... ? If not, how to do that?
BR,
Jick
(3,254 Views)
In the report options -- report path file name -- file name /directory options --- select "specify report file path name by expression".
You will need to add "\\ [<FileDate>]"\\   the file date appropraitely example shown below :
 "<ClientFileDir>\\[<FileDate>]\\Report_[<FileDate>]\\<ClientFileName>_Report[<FileTime>][<FileDate>]<Unique>.<FileExtension>"
Hope this helps.
(3,249 Views)
I am using TS 4.0. There is no "specify report file path name by expression" option.
See attachment.
BR,
Jick
(3,246 Views)
