NI TestStand
How to see all the step done by a for or while loop
To save dev time of multiple test UUT I have developed a VI that executes the content of a script.
Each script contains several batches of tests (about a hundred)
Each batch in this script results in a measurement.
The VI executes only one test batch ,then delet it of the script and gives its result.
I execute the VI under teststand in a step action in a for loop. While the script is not empty TS continues to execute the step.
The batches are executed one after the other. This part works very well.
My problem is on the operator's execution windows, he will only see a line with a result that will flash green/red at the rate of the various results.
I would like to display the X steps one under the other. If the loop is performed X times the operator want to see X lines .
What is programmed :
What i want the opertor see :
Is It possible ?
Thanks you .
Message 1 of 1
(743 Views)
