NI TestStand
Logging frames via ni xnet
Hi all ,
I am actually test an ECU using  CAN module, I  send and receive frames via ni_Xnet .
I need to log all frames while the test is running . I used the Vi offered by NI from exemples which called "CAN input stream to TDMS LogFile"  in New thread  .
The issue that I faced are :
_ I can't log frames which is more than 8 bits
_ after two or three tests I lost the connection with CAN
If you  need more information ask me ,
Thank you
(788 Views)
Can you send me the VI for the logging?
(415 Views)
