NI TestStand
How to retrieve sequence file with elder version?
Hello:
     when i set sequence file version to auto update, when i save sequence file, will see the version number increase automatically.
     Is there any way to retrieve sequence file to a former version?
(2,476 Views)
Sequence Files don't save all of the versions like that.  That is just a number saved in the file so you can quickly identify what rev it is.
You should be using source code control for this purpose.  If you are not using source code control then maybe your IT department does a backup of all the computers?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,372 Views)
Thanks for your reply~
For the SCC tools, do you have some recommendations?
(2,364 Views)
