NI TestStand
How to pass a container to LV using LV TestStan API
Hi all,
I try to pass a container from TS to LV and read it via TestStand API in LV project.
The problem is that in LV I have a cluster with different data type and in TS I can "emulate" the cluster with a container, but I can  not be able to read the cluster\container in LV side using the TestStand VI.
also set the polymorphic as object the result is the same, i can not read the data into the cluster
Do you know if is possible and if is possible use a LV typedef in TS ?
(1,128 Views)
Accepted by zundap1970
As far as I know you have to get the individual elements independently.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,082 Views)
