NI TestStand
How to index an array container and write the data in the spesified in the container in a Test Step of teststand
Can I get an advice on indexing an array of container using teststand expressions and adding the value in the same container and update the value in the Teststep. The Portion which i need to index and update is shown in below picture. Please share some ideas to do the same.
(4,389 Views)
Step.TS.SData.Calls[0].ClassName = "Whatever you want here"
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,368 Views)
Hi Jiggs IT worked.
(4,358 Views)
Hi All,
Actually my requirement is Load a .dll file into the Assembly path using the expressions into my .net code module step as shown in the figure1.png, and to full fill that i am writing the expression as shown in figure2.png. but i am unable to load the .dll file using the expression as i am doing now. Please let me know if i am doing it wrong and advice me in what metheod i can load the .dll file using the expression.
(4,357 Views)
