NI TestStand
write TDMS file in TestStand using dotNET adapter
I have simply an array of LabVIEW waveforms in Teststand, and I want to write them in a TDMS file. An easy way would be to call a VI, which does it. But if there would be a dotnet assembly with TDMS functions, no VI would be needed.
I searched on the net, and I found a description with an assembly, where nationalinstruments.tdms is included. But as I understood, this will be installed along with Measurement Studio - which I don't need.
regards
Madottati
(3,447 Views)
Hello Madottati,
I think the easiest and fastest way is to use a VI.
You are right the .NET assembly is included in Measurement Studio and therefore you need a licence.
Is there a special reason why you not want to use a VI?
(3,398 Views)
