How to implement "if/then/else" or "case" logic in a Statement Expression?
I need a loop in my test sequence, so I define a Locals.LoopIndex which is of type Number, and I also define a Locals.PromptMessage, which is of type String. Within the loop body, have a statement step, in which I want to assign Locals.PromptMessage different strings according to the value of Locals.LoopIndex. The logic is like this (in suedo code)
case Locals.LoopIndex:
1: Locals.PromptMessage = "string1";
break;
2: Locals.PromptMessage = "string2";
break;
or
if (Locals.LoopIndex == 1)
then Locals.PromptMessage = "string1";
else if (Locals.LoopIndex == 2)
then Locals.PromptMessage = "string2";
How can I implement this in the Statement Expression?
Thanks!
Message 1 of 10
(32,544 Views)
You can use the conditional expression (not sure what it is called). Syntax is Locals.variable=(BooleanExpression?ValueIfTrue:ValueIfFalse). To implement your pseudo code it would look like this:
Locals.PromptMessage=(Locals.LoopIndex==1?"string1":"string2")
This means the same as:
If Locals.LoopIndex=1 then
Else
End If
Another way to do it is like this, but the first method is preferred:
Locals.LoopIndex==1?(Locals.PromptMessage="string1"):(Locals.PromptMessage="string2") -- must use parenthesis as shown
This syntax is BooleanExpression?(Statement if BooleanExpression is true):(Statement if BooleanExpression is false)
You can nest the expression to create ElseIf conditions:
Locals.PromptMessage=(Locals.LoopIndex==1?"string1":(Locals.LoopIndex==2?"string2":"string3"))
ElseIf Locals.LoopIndex=2 then
Else
Locals.PromptMessage = "string3"
End If
I don't know if there is a limit to the nesting.
Hope this helps.
- tbob
Inventor of the WORM Global
Message 2 of 10
(32,535 Views)
I don't know what happend but the frowny faces replaced the colon in my previous reply. Please substitute a colon for the faces.
- tbob
Message 3 of 10
(32,533 Views)
Sorry, the frowny faces replaced a colon followed by an open parenthesis. I guess this forum uses the colon for special icons.
Testing : ( - colon, space, open parenthesis
😞 - same without the space.
How about 🙂 - colon, closed parenthesis.
- tbob
Message 4 of 10
(32,530 Views)
I tried the nested way - I nested it 16 times, and it works! Thanks a lot!
By the way, the faces testing are interesting 🙂
Thanks again,
Eileen
Message 5 of 10
(32,524 Views)
Note that if you need to use multiple expression statements for each condition, the following syntax is acceptable and more readable:
Locals.LoopIndex==1? //IF
Locals.PromptMessage="string1",
expression2,
expression3,
😞  //ELSE
Locals.PromptMessage="string2",
expression4,
espression5,
Message 6 of 10
(29,828 Views)
post expression if condition how to implement it on action step
Marwah
Message 8 of 10
(1,004 Views)
Action Steps never Pass  or Fail
You will need to use a Test.  In your case, a MultipleNumericLimitTest might be suitable
Message 9 of 10
(1,000 Views)
Please ignore:
since author has edited the original question this answer is unrelated to the actual question
Message 10 of 10
(970 Views)
