NI TestStand
How to get sequence overall result in LabView ?
Would anyone can help with this tiny problem ?
We have a batch (.bat) that launches a given list of TestStand sequences, which works as expected.
However, we would like to monitor the result of each sequence and display it to the operator.
Our idea is to get the sequence result in a VI, run at sequence end, and add it to a queue, that will be retrieved and displayed on a VI monitor, run separetly.
The only problem we have left is to be able to retrieve the sequence global result. Any idea or suggestion ?
Raphael
(5,070 Views)
I'd rather use an UI Message to send a string with the step name and result.
Rodéric L
Certified LabVIEW Architect
(5,068 Views)
Thanks. The problem is not the monitor and how to pass the information to it.
We already have a test monitor (using queues) that is working as expected.
The test sequence is queuing information, mainly at steps end with step result, and the monitor is displaying information from that queue. The queue is resseted at each sequence start.
We would like to derivate that monitor to display only sequences (launched by a batch file) overall-global-final result of all the sequences ran. Using UImessage is maybe a better way, but we do not want to spend time re-writing another monitor.
The problem is how do we retrieve this overall-global-final sequence result in LabVIEW ?
(5,064 Views)
Maybe this thread will help
http://forums.ni.com/t5/NI-TestStand/Convert-resultlist-container-to-string-for-report/m-p/943465#M2...
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,045 Views)
Hi
... and for a complety stand-anlone report stuff
Take a look at this
http://forums.ni.com/t5/NI-TestStand/Saving-ResultList-as-binary-file/td-p/653522
Juergen
--Signature--
(5,039 Views)
If you are talking about getting the status of your Main Sequence, Passed, Failed, Terminated, Error, then look in either process model execution entry point sequence, Test UUTs or Single Pass, and check out the step status of the step MainSequence Callback, step.result.status.
You could add a single step to your process model just after MainSequence Callback to read the status and drop it on your que. Check out the expression in the precondition of the statement step Record MainSequence Failure in the SequentialModel.seq as an example.
cc
(5,028 Views)
Accepted by phramusca
Thanks for all your answers. We finally ended by queuing sequencefailed value from sequence context property node.
I also discovered the TestStand database logging and started to use this in parallel.
Thanks again
(5,014 Views)
