NI TestStand
How to get indicator from HandleUIMessage vi to Top Level.vi
I want to custumize Simple user interface for testand (Labview).
I read all of this:
https://www.ni.com/en/support/documentation/supplemental/14/working-with-the-teststand-simple-user-i...
At the : "Handling additional events" there shows how to create callback vi so that we can do some event handling code when UI message comes:
Untitled.png But If I put some boolean indicator here inside and connect it to connector pane to be used for example to indicate some event is done, i get broken Wire:
Why this is happening and how to get this indicator to the top level vi?
(2,651 Views)
I have some presentations for this in our TestStand user group.  Hope these help:
Presentation: https://forums.ni.com/t5/Utahns-Using-TestStand-UUT/TestStand-User-Interfaces-pptx/gpm-p/3537676
Source code: https://forums.ni.com/t5/Utahns-Using-TestStand-UUT/UpdateChartUI-zip/gpm-p/3537677
The key is that you need to pass a reference to your FP object into the callback VI.  The User Parameter has to match so you don't have a broken callback wire.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,640 Views)
The presentation is ok, but I have some additional questions since I cannot realize it...
I will use TS Simple UI.
1. First I create Chart indicator on the top level VI front panel like this and create reference of this chart:
2. Second I drag and drop Chart reference created in step 1 into UI Type Def. inside of visible controls section (see red arrow):
3. Then I connect Waveform chart reference into initialization cluster:
4. When I create UserMessage Event Callback, I get broken wire, it says thath TestStand UI Data cluster contains an error:
What I'm doing wrong here?
(2,620 Views)
(2,620 Views)
It looks like you just need to reconnect the control to the type def.  In fact I would make it a strict type def if it were me.
One way to reconnect it is just replace it.
jigg
CTA, CLA
testeract.com
(2,611 Views)
