NI TestStand
How to display sequence file version in report?
Just set the string result and the string limits to the same value. That will ensure the step always passes.
You can do this in your code or you can copy the Step.Result.String to the limits in the Steps post expression.
Regards
Ray Farmer
Regards
Ray Farmer
Message 11 of 13
(1,649 Views)
I did not have the 3.1F1 path installed.  After the install the test fails as you have indicated.  This is good to know.  Copying the variable containing the revision into the step.limits.string in the pre-expression as mentioned above seems to cover this issue.  Hope all this helps.
Message 12 of 13
(1,464 Views)
Thank you very much everyone.  These suggestions have been very helpful and brought up some good comments internally.  I appreciate you taking the time to answer my question.
Message 13 of 13
(1,448 Views)
