How to display Nominal Values at Limit Test in XML test report
Is there a way to display the nominal values in the test report if there is a "GELE" comparison.
Currently, nominal values are displayed at EQT comparison only.
My setup is the default horizontal.xsl template which generates the xml report in Test Stand 2019.
I tried to modify the horizontal.xsl file, but without success so far.
Please is there any idea how to fix this?
(647 Views)
Only EQT comparison steps have the Nominal Value property. Since it doesn't exist otherwise, it doesn't get displayed.
(640 Views)
Thank for your quick response Oli.
My dataset in the sequence file contans highlimit, lowlimit and nominal value.
Does this mean it is not displayed even if the variable nominalValues is set.
(637 Views)
Accepted by random_guy_001
The ResultList-Variable is what matters for result generation.
In the screenshot you can see the difference between a EQT and a non-EQT NLT.
(633 Views)
Hi Oli
Thank you very much for explanation.
(628 Views)
