NI TestStand
How to converting string to array
Hi all
  I have a demo,when input string "test123" need to assign array as uutdata[0]="t",uutdata[1]="e",uutdata[2]="s",uutdata[3]="t",uutdata[4]="1",uutdata[5]="2",uutdata[6]="3",why is only assign in element[0],thanks!!
why only assign in element[0]why only assign in element[0]
(3,838 Views)
1- You need to get the length of your string in 'SerialNumber'
2- Resize your array 'UUTdata'
3- Fill in 'SerialNumber' into 'UUTdata'
(3,812 Views)
Hi hbs
   Thanks for your reply,I have got input serial number length and resize the array,only don't know allocated the string in array elements, the procedure as below:
1)FileGlobals.Number_of_length = Len( FileGlobals.SerialNumber)
2)SetNumElements(FileGlobals.UUTdata, Len(FileGlobals.SerialNumber))
3)FileGlobals.UUTdata =  Split ( FileGlobals.SerialNumber,",")
I think is wrong with procedure(3),how to fix it,thanks!!
(3,808 Views)
Accepted by Sam.Huang
use Mid
String Mid(String string, Number startIndex, [Number numberOfCharacters])
Example: of course, you can put it in For loop
Parameters.Arr[0] = Mid(Parameters.Serial, 0, 1),
Parameters.Arr[1] = Mid(Parameters.Serial, 1, 1),
Parameters.Arr[2] = Mid(Parameters.Serial, 2, 1),
Parameters.Arr[3] = Mid(Parameters.Serial, 3, 1),
Parameters.Arr[4] = Mid(Parameters.Serial, 4, 1)
(3,802 Views)
