How to convert noraml string to hexa string in teststand
I need to send RS232 command in hexa format (type - string), but in teststand it is taking as ASCII characters.
Tried in Labview, working fine, but in teststand i m facing difficult.
Please help !
Thank you 🙂
Message 1 of 8
(4,651 Views)
Sorry it is Normal string to Hexa string
Message 2 of 8
(4,650 Views)
How the "converted" string should look like ?
Like that: "123ABC" --> "313233414243" ?
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 3 of 8
(4,641 Views)
Example : 02000111800151CA , which is of 8byte. This same hexa valu i need send through RS232.
when trying with Labview i changed the display format to Hexa and transmitted the command, its working. But how to do that in Teststand, is the question.
Message 4 of 8
(4,636 Views)
that means you like to convert  an UINT64 to string right
Regards
Juergen
--Signature--
Message 5 of 8
(4,632 Views)
Just for an Example, which TS version do you have?
Juergen
--Signature--
Message 6 of 8
(4,631 Views)
I m using 5.0 and the final output should be hexa string. Convert from number/string no matter.
Message 7 of 8
(4,627 Views)
Here you are,
Locals.strHex = Str(Locals.u64_Val,"%x")
Regards
Juergen
--Signature--
Message 8 of 8
(4,624 Views)
