How this DAQmx function works
Hello, I am trying to understand how this function works
NIDMWaitXAnalogLineWin
This is the expression I want to understand how it works,
This function is used to get data from resistance
Thanks for your help.
Juan Coy
(1,994 Views)
Accepted by JuanCoy
You need to find documentation for the C:\DelphiTestSystem\TestModules\Libraries\DAQmx.dll or for the custom Delphi Numeric Limit Test step. The expression is simply a call to the NIDMWaitXAnalogLineWin function from C:\DelphiTestSystem\TestModules\Libraries\DAQmx.dll with parameters specified in the parameters list displayed on the first screen.
Check this: https://forums.ni.com/t5/Multifunction-DAQ/missing-dll/m-p/681593#M38709
and this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8lkSAC&l=pl-PL
It is possible that you have some custom dll build?
Michał Bieńkowski
CLA, CTA, CPI
(1,915 Views)
