How i can dynamically (at Run time) switch the Models?
I need during my application Run-TIme to switch SequentialModel.seq to SequentialModel_2.seq or SequentialModel_XYZ.seq (custom).
How i can do it? It can possible do with Engine?
Can you, please give example of switching???
Thank you in advance, Yuri
Thank you & Best Regards
*I use LabVIEW 2018 & TestStand 2021 versions
(3,813 Views)
Accepted by Yuri_IL
You can set the property Engine.StationOptions.StationModelSequenceFilePath to switch models at run time.
(3,810 Views)
Where to you put "Engine.StationOptions.StationModelSequenceFilePath=My_custom_model.seq" in your sequence file?
Message Edited by mike_22 on 07-08-2009 04:51 PM
(3,649 Views)
regarding calling a different process model:in your subsequence call you need to select "Use new Execution" in the Execution options and then in the Advance sequence call setting you can choose the process model you want to run for this sequence
Ask me for clarifications if you need
Message Edited by Yuri_IL on 07-09-2009 09:37 AM
Message Edited by Yuri_IL on 07-09-2009 09:43 AM
(3,635 Views)
