NI TestStand
How do I 'grab' a copy of the current UUT Serial Number within TestStand?
I am trying to access the UUT Serial Number typed in at the start of each UUT Test Run, in TestStand, so that I can write it to a pre-defined Database. How can I do this?
(5,985 Views)
You can obtain the SerialNumber by using the lookup RunState.Caller.Locals.UUT.SerialNumber, I am assuming you will be doing this from somewhere within the MainSequence.
I have attached a TS3.0 SequenceFile, it obtains the SerialNumber and displays it in a message popup.
Regards
Ray Farmer
Regards
Ray Farmer
(5,976 Views)
Although Runstate.Caller.Locals.UUT.SerialNumber will return the serial number from within MainSequence, you will have to modify this for a subsequence such that you prepend a "Runstate.Caller" for each level of sequence call you have. So to get this from a subsequence called by MainSequence, you will need Runstate.Caller.Runstate.Caller.Locals.UUT.SerialNumber. As this might get confusing and error prone if you are moving sequences around, I suggest using:
Runstate.Root.Locals.UUT.SerialNumber
--Peter
(5,964 Views)
Thanks for the help.
Very much appreciated! May be back for more help as I'm a TestStand novice!
Regards.
Neil.
(5,953 Views)
