NI TestStand
How to get step results without tracing?
Hi everybody,
I've written an operator interface in VB6 and I need the result of each step.
The problem is, that I can't use tracing.
Is there a posibility to get the results without tracing?
Thank you in advance for your help!!
(3,410 Views)
Is this the result of each step displayed in the Operator Interface or the results in the report file?
Regards
Ray Farmer
Regards
Ray Farmer
(3,403 Views)
Shouldn't it be the same?
(3,392 Views)
The Operator Interface displays each step in the window when tracing is enabled, otherwise nothing is displayed during execution for the sequencefile.
Providing the Report is enabled, either in the configuration report options or via the Sequence Callback ReportOptions and the Sequence being run is using the process model entry point (Single Pass or TestUUT's), a report will be generated. Tracing doesn't affect whether a report is generated.
Regards
Ray Farmer
Regards
Ray Farmer
(3,384 Views)
