NI TestStand
How can I find the subsequence name?
I want to use the subsequcename, but I cannot get it. Do you have some suggestions?
Message 1 of 14
(5,507 Views)
Can you Brief your requirment much more clear?
Do you want to use the sub sequence name during run time?
Message 2 of 14
(5,502 Views)
I assume that you want to call the subsequence. Correct?
If so, use the Sequence Call step and configure the subsequence as module.
If you want to rename the subsequence, select it in the sequence pane and press F2 (standard key in Windows for renaming things).
Norbert
Norbert
Expert: Geometry
Message 3 of 14
(5,498 Views)
Yes, I want to acquire the subsequence name in run-time. I have a sequence file consists of one mainsequence and too much subsequences, so I want to acquire their names easily without manual operation.
Message 4 of 14
(5,497 Views)
Thank you all the same.
Message 5 of 14
(5,496 Views)
What is the purpose of this? In case you want to have this for documentation purposes, there is the "Sequence File Documentation" tool (Tools) you can use.
Norbert
Norbert
Expert: Geometry
Message 6 of 14
(5,490 Views)
You can aquire the subsequence name at run-time, from within the subsequence, by using the following expression:
RunState.Caller.Step.Module.AsSequenceCallModule.SeqName
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 7 of 14
(5,486 Views)
I want to generate a custom report by LabVIEW, so I should give the subsequence name to a VI to finish the report.
Message 8 of 14
(5,485 Views)
Besides i fear that you create yourself unnecessary work (read: instead of modifying TS reporting creating a complete new one), you should have step storing "RunState.Sequence.Name". You then pick up this variable in your LV reporting code.
Norbert
Norbert
Expert: Geometry
Message 9 of 14
(5,481 Views)
Thank you very much! The report generated by TS is too complex to our workers, so I want to find a friendly one.
Message 10 of 14
(5,475 Views)
