10-10-2017 04:36 AM - edited 10-10-2017 04:39 AM
I developed a Step Type with labview and in the edit step I have a problem with my labview code. When I write for exemple locals.texte ( locals.texte = "test") in the UI expresionEdit Control , the property node DisplayText return "locals.texte" like result and not "test". how can I use it to display the contents of the variable.
10-10-2017 08:47 AM
I am assuming you are wanting the value of the variable rather than the lookup string.
try
10-10-2017 09:10 AM
Thank you for your answer.
yes this is exactly what i want, i just tested your example in my edit step type I have an empty value, and if I call the VI in TestStand it works. is what I need to do a special configuration for my stepType to work?
10-10-2017 03:50 PM
can you post your step type project, if you can post it as LabVIEW 2015.
10-11-2017 07:53 AM - edited 10-11-2017 07:57 AM
here are my VIs , my project is too bih so I will post just the two VI of the StepType ( EDIT and Post Step) with 14 like Version of LabVIEW because I don't have version 15.
10-11-2017 10:06 AM
Ok I'll have a look.
I did create a StepType using the modified VI and it worked for me. The only extra thing I did was to make the VI a dialog in the VI properties so that it displayed the front panel when invoked by the Edit..
10-11-2017 10:39 AM
I tried your Edit VI and it worked for me.
How are you passing the value back into the Step?
10-11-2017 11:14 AM
In the parameter name "String " I put a "Step.Text" and Text is a String
10-11-2017 12:18 PM
So is Text a step property?
As in my example where I have Response?
10-12-2017 08:11 AM
Yes Text is a step property, as in you example where you have Response, is what there is another configuration to do ?
