NI TestStand
Help building a conditional expression, please
I have an IF condition and I'm trying to build a conditional expression for it, but due to my lack of syntax knowledge I am unable to succeed, could someone here help me out, please?
So, basically I have 5 sockets which all run a sequence called INIT, in this sequence I interrogate the UUT and depending on result I set 1 of 5 bools true/false:
Bool_index0, Bool_index1, Bool_index2, Bool_index3 and Bool_index4
I want to have a single conditional IF statement and would like to use 'RunState.TestSockets.MyIndex' to tell the program which bool to evaluate.
Is it possible to write something like this? I want it to look for the specific Bool_index based on which socket is executing the sequence
IF -> Bool_index(RunState.TestSockets.MyIndex) == False
(320 Views)
Accepted by JohnatanBravo
Try
Evaluate("Bool_index"+Str(RunState.TestSockets.MyIndex))
Replace Bool_index by the complete LookupString
(295 Views)
That worked like a charm, thank you very much for a quick response. Gotta remember this one!
(279 Views)
