When using the on-the-fly report option with the conserve memory option, my html report files end up with unusual empty lined boxes. If I uncheck the conserve memory box, then all is well. I have the report filtering on to log only failed tests. I've attached an example report log. On longer tests, this can consume several Mbs of wasted space. I also log any step.reporttext which is non-blank. Anyway to stop this behavior?
