NI TestStand
HTML problems using on the fly report option and conserve memory
When using the on-the-fly report option with the conserve memory option, my html report files end up with unusual empty lined boxes. If I uncheck the conserve memory box, then all is well. I have the report filtering on to log only failed tests. I've attached an example report log. On longer tests, this can consume several Mbs of wasted space. I also log any step.reporttext which is non-blank. Anyway to stop this behavior?
(3,302 Views)
Hi
Can you please post a test sequence(using None Adapter steps) which reporduces this problem.
Thank you
Anand Jain
(3,302 Views)
I've attached a simple sequence (none adapters) which demonstrates this behavior. If you run it with the NI sequentialmodel.seq, on-the-fly reports checked and "conserve memory..." checked, the report log will contain the lined boxes. If you uncheck the "conserve memory..." box, the report looks normal.
(3,302 Views)
Hi
I have reproduced this problem here. Can you please contact support and they should be able to help you.
Anand Jain
National Instruments.
(3,302 Views)
