NI TestStand
Goto PreUUTLoop from Main Seq
Not sure why I kept missing PreUUTLoop in your posts.  And now that you mention SAP it make a whole lot more sense... 😉
PreUUTLoop is not othe correct location for this.  If you look at the link that both Rene and myself posted there is a flow of the process model.  In there the looping is from PreUUT to PostUUT.  If you need to loop before and after that then you would need to build this into the process model.  Much like they've done with PreUUT and PostUUT but lopoing from PreUUTLoop to PostUUTLoop.
Do not try and do it from the client sequence file.  The process model is for overall test flow.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 11 of 13
(2,200 Views)
thanks Jigg,
is it recommended  to change the process model (sequentialmodel.seq)  or shld it be the last resort.
In case thts the last resort I can look some  workaround for the same.
Message 12 of 13
(2,197 Views)
There is nothing wrong with editing the process model.  I would copy it and rename it though.  Read that document that we linked in previous posts.  It describes the best practices for process model customization.
The main thing to avoid is coupling the process model with your client sequence file.  A process model should be able to run most client sequence files if not at least a family of client sequence files.
jigg
CTA, CLA
testeract.com
Message 13 of 13
(2,195 Views)
