NI TestStand
teststand-Check file attribut (timestamp of last save)
Hello all,
Is it possible to get the Information about the last time when a file was saved. in LabVIEW there is a function called get file info but I would like to do it with the functions of the TestStand API.
I would like to read the exact time when the file was saved.
Greetings Walter
(4,346 Views)
Hi Walter,
in TestStand(5.1) there not such a feature implemented.
But you might use .Net System.IO.FileInfo Class instead
Just take a look at the attached example
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,341 Views)
Hello Juergen,
Thank you for your answer.
I am using TestStand 2010. Could you save the sequence for that version so I can open it.
Regards Walter
(4,337 Views)
here you are.
Regards
Juergen
--Signature--
(4,331 Views)
