GetReportFilePath Callback Don't Work
I want change my report path to "D:\\" by sequence or by TS API, report name should be keep "$(ClientFileDir)\\$(ClientFileName)_Report-$(FileDate)-$(FileTime)-$(Unique).$(FileExtension)", only the path need change to "D:\\", I don't want using "Result Processing" dialog,I have read a lot of related posts,find the best way is overwrite GetReportFilePath callback.
  I don't know why the GetReportFilePath Callback don't work, thanks!
(4,921 Views)
Seems like nobody interested in this topic.
(4,899 Views)
Accepted by topic author TabZhang
I put it in client sequence "ReportOptions" like below, it work now.
Parameters.ReportOptions.Directory = "D:\abc",
Parameters.ReportOptions.DirectoryType= "SpecificDirectory"
but I don't know why it don't work it i put it in model sequence.
(4,893 Views)
Hi TabZhang,
Using the ReportOptions callback is the appropriate location to set the report path programmatically, so your current solution is correct.
The GetReportFilePath callback exists so the client sequence file can inspect the report file path if needed, and is executed during the Model Plugin - UUT Done and Model Plugin - Batch Done sequences of the process model. ReportOptions is called at Model Plugin - Begin. This is important because the actual file that contains the report is being created during the Model Plugin - UUT Start and/or Model Plugin - Batch Start sequences which execute after Model Plugin - Begin, but before Model Plugin - UUT Done.
Steven Gloor
Staff Customer Engineer - CTA, CLD
(4,834 Views)
Hi Steven,
OK, Thanks for your clarification!
(4,825 Views)
Hi Steven,
If I want to change the report path after uut done How should I do?  and i observed the report file generated after UUT Done executed
(584 Views)
You should be able to achieve this using the ReportOptions DIalog Box.
Are you actually refereing to the path ("folder") where the file should be stored or the file name?
(443 Views)
