Get StepType reference
I want to change a steptype with the Teststand API in LabView by using the method ChangeStepType. The input parameter is a stepTypePtr as StepType. But how can I acquire a StepType reference as a parameter.
Thanks for help!!!
Regards
Matthias
Message 1 of 9
(4,227 Views)
Look at the example supplied, this gets the StepType Ref so as to get the Name of the StepType to do a comparison with the required StepType (see the Locals variable) to change some the the steps properties.
It should help.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 9
(4,215 Views)
Hi Ray,
thanks for your answer.
Yes, it would worked with your first example, but I want get the reference by the way described in the Teststand API Reference Help. There ist written for the method ChangeStepType:
ChangeStepType Method
Syntax
Step.ChangeStepType ( stepTypePtr)
Purpose
Changes a step's step type.
Remarks
Returns an error if the step does not allow changing its step type. To avoid this error, only call ChangeStepType if CanChangeStepType returns True.
To acquire a step type to pass as a parameter, call Engine.GetTypeDefinition and pass the name of the desired step type, then query the returned PropertyObject for its StepType interface.
Parameters
stepTypePtr As StepType
[In] The step type to which you want to convert the step.
My problem is to convert the reference, which get by the call Engine.GetTypeDefinition into a StepType reference.
Do you have an idea?
Thanks for help!!!
Kind regards
Matthias
Message 3 of 9
(4,206 Views)
I think you can pass the reference return back from the GetTypeDefinition, as the parameter to the Step.ChangeStepType method.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 9
(4,166 Views)
I have right now stumbled upon the same problem. You cannot pass the reference received from the "IEngine.GetTypeDefinition" method to the "Step.ChangeStepType" method, as it has the wrong type (TS.PropertyObject as opposed to TS.StepType).
What must I do to get the StepType reference needed by th ChangeStepType method? The Help says that "... call Engine.GetTypeDefinition and pass the name of the desired step type, then query the returned PropertyObject for its StepType interface."
What exactly does "query" mean, besides StepType "interface"?
Martin
Message 5 of 9
(3,986 Views)
All right, it's sufficient just to typecast the PropertyObject reference to the desired StepType type. It's always easy, when you know how to do it ...   :-0
Martin
Message 6 of 9
(3,982 Views)
How does one actually typecast in TestStand?
Thanks.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
Message 7 of 9
(3,450 Views)
OK - I just figured it out!  Use the AsPropertyObject method. ie. Using the ActiveX adapter, set Object Class to StepType, and Call Method AsPropertyObject.  The object reference passed out will be of type StepType. Then pass this StepType into the next ActiveX step. ie ObjectClass: Step, CallMethod ChangeStepType..
Christopher Farmer
Message 8 of 9
(3,448 Views)
In LabVIEW, the Variant to Data function is generally used to typecast TestStand references, i.e. Module reference to LabVIEWModule reference or PropertyObject reference to StepType reference.
Hope this helps.
Manooch H.
Message 9 of 9
(3,382 Views)
