Get Object Reference to new execution
I'm testing some concepts of parallel execution of different test in parallel on a single DUT. The idea is to start multiple tests as sequence calls in new threads as done in the  ParallelExecution.seq example supplied with test stand. The Wait function later in the code also features the "Specify by Object Reference to the Execution" option but I haven't figured out yet how to retrieve this reference...
Is there any easy way?
Cheers
Oli
(5,333 Views)
Accepted by Oli_Wachno
Oli,
simple answer. When configuring the SequenceCall step to "New Thread", the "tool button" next to the right of the combobox is enabled (Sequence Call Advanced Settings).
Press it.
Norbert
Norbert
Expert: Geometry
(5,332 Views)
Hi Norbert,
sometimes things are simpler than they seem to be Smiley Happy
Thanks a lot!
Oli
(5,328 Views)
