‎10-29-2025 05:10 AM
My question is, after completing the Test Sequence. It is generating two reports as shown In the figure. In the first report, there is no Data inside it. And Second with .xml format all the data is there. I don't want to generate the first file.
I have do this setting in the Report Option. I only want to generate .xml Format.
Am I missing something?
Please guide me thorough it.
‎10-29-2025 05:31 AM
StationOptions-> ResultProcessing
uncheck the report you dont need
‎10-29-2025 05:41 AM
I have only checked one Report Template.
‎10-29-2025 06:06 AM
In your original post, you also have the "Generate HTML" option set.
This will give you the originally configured XML plus an HTML version.
Yet this doesn't explain, why one should be empty.
Try unchecking "Generate HTML"
‎10-29-2025 06:26 AM
Yes, I have also tried that.
By unchecking "Generate HTML" I can only get one file but in this file. However, I was unable to find the data in that file.
And by checking on the "Generate HTML" I can get the report. in .xml Format
