Generate XML report then display like HTML with specified formate
Hello,friends I want to generate XML report then use XSL to parse it,report will display like HTML with specified formate like attachment,any ideas? Thank you Alb
(4,029 Views)
You forget your attachment!
Regards
Ray Farmer
(4,028 Views)
Sorry,I attached,thank you
(4,009 Views)
Why I can not attach the picture by adding brower menu?
(4,008 Views)
You can not use BMP file type, try JPG or PNG
Regards
Ray Farmer
(4,005 Views)
try PNG ,jpg upload fail
(3,990 Views)
Hi Ray,
I don't why I can not upload any format picture,so I listed the display as below:
Test Result        Company Logo
SN                   1111        User                          Operator
Status              Fail        Factory                     SE
Product            xxx        Tester                        xxx
Start time         xxx        Line                          xxx
Test time          xxx
NAME                               STATUS           VALUE                          LOW               HIGH                   RULE
1.0 Pass/Fail     Test           Passed             True                             True                                             EQ
2.0 Less than    Test            Failed               15                                10                                                LT
3.0 String Value Test           Passed          A string from the limit file   A string
                                                       End of Report
Could you give me some suggestions?
Thanks a lot
Alb
(3,976 Views)
