NI TestStand
Finding an elements in array
Two array A n B. I need A + (n-1 )B ,add content A with previous B elements. Is there a function like GetArrayOffset to get previous index array content? I use the format -1, teststand inform out of bounds error, but when I run the sequence file, it work. How to stop teststand informing the error?
(2,793 Views)
Hi mingchew,
I guess you get the error on the first iteration when n = 0 and as a consequence you are using -1 (0 - 1) as an index into B?
You will need decide what to do on the first iteration when you don't have a previous value to use to index into B then use a conditional statement that decides what to do based on the value of n.
Hope this helps
Steve
(2,774 Views)
