NI TestStand
File Reader, directory path format
   I am currently debugging a file reader in NI TestStand.  I am on a
LabView 2013 version:
This call to a local directory or path "C:\\Users\\eng\\Documents\\PaulG\\File"
is successfully read by my VI application...  Notice the "double" back slash?
Now , I am trying to do this coming from a network , below example:
"\\IP_address\\eng\\2013\\File"      123.123.123.123  = IP Address, example only)
It does not work, I cannot read it.  What is the correct "format" path to call it?
Then I came across another application on LabView 2018:
"\\\IP_address\eng\2018\File"  (notice this time it is triple backslash?? and single slashes, as opposed to double backslashes above)
This is working as per the user of this one.
What is happening here?
Big thanks,
Paul
(1,961 Views)
I find that for network drive locations, I need to double up on the slashes, like "\\\\first\\second\\third"
(1,939 Views)
noted.  big thanks!
(1,511 Views)
