NI TestStand
Data Streams TestStand: Write Record
I am trying to write the outputs I get from a Veristand project to a CSV file. I am using the ASAM XIL steps for this. I do not understand the step settings for Write Record. I am using Get Variable Values to link to my output alias, how do I pass that to the write record step?
I've attached a screenshot of the step settings for write record step.
Thanks in advance.
(2,319 Views)
I'm a bit confused, in the question you have mentioned VeriStand, however it is written in the TestStand thread and the subject is also TestStand.
However, if you are looking for a method to log data via VeriStand then check following links:
https://zone.ni.com/reference/en-XX/help/372846M-01/veristand/spe_tutorial_example4/
https://forums.ni.com/t5/NI-VeriStand/VeriStand-data-logging-in-LabVIEW/td-p/3924622?profile.languag...
And for TestStand:
https://zone.ni.com/reference/en-XX/help/373892J-01/tssemiconductor/reports_data_logs/
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DdM6SAK&l=en-US
__________________________________________
The best way to thank, is to give KUDOS
(2,255 Views)
