NI TestStand
Error related to bursting a pattern
I am trying to burst a pattern in a sequence. I am able to burst a pattern without errors, but I am not getting a required result for that.
But when I run a pattern manually in digital pattern editor. I am able to get the required result.
I have enclosed the code that I have used in running a pattern.
(1,229 Views)
Insufficient information to help you. Please explain more about the error and how you're using the code.
As per your code, you just burst the pattern but do not read back the pass/fail result which in turn has to be published to TSM in order to log to STDF.
Santhosh
Soliton Technologies
(1,204 Views)
