02-10-2020 12:52 AM
I am using Teststand 2016 64 bit and LabVIEW 2018 64 bit. i am trying to load Agilent 3446 labVIEW drivers in test stand using LabVIEW run time engine. i am getting the following error
" Failed to load VI 'C:\Program Files\Teststand Scripts\DMM_Measurement.vi' in the LabVIEW Run-Time Engine version '18.0'."
I have many other VI's called in the same Sequence. i am able to successfully load the other instrument driver VI's but not the Agilent one. Any idea what i am missing?
02-13-2020 03:46 AM
Hi
Can you open and run the Agilent VIs with LabVIEW 2018 64 bit?
If LabVIEW is installed on your PC. Can the sequence be loaded and executed when the LabVIEW adapter is set to LabVIEW Development System?
Chris
