NI TestStand
Error -17001 source 'TSAPI' when reopening saved sequence-file with custom step type
I am trying to test a custom StepType that has an .Net-Edit and a C/C++ DLL-Post-Step Substep, in a simple sequence file. The sequence-file contains a single call of the custom StepType. However, when I save and reopen the sequence file I get the following error:
The StepType is saved in a TypePalette file, as well as in the sequence file and is not changed between saving and re-opening.
(5,294 Views)
Hi bleiber,
Did you manage to solve your problem? I was checking for similar type of issues reported here via forum and found this post summarizing pretty much suggestions you would be able to find in other threads.
https://forums.ni.com/t5/NI-TestStand/Move-step-then-i-got-this-quot-Error-Code-17001-quot/td-p/1722...
Take care,
Tomek
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(5,265 Views)
Hi Tomek,
thank you for your answer. Unfortunately, the problem still persists. I haven't installed LabVIEW or LabWindows/CVI so I would exclude this error cause.
Also, when I try to copy the step into another sequence the same error pops up:
However I noticed, that the error only occurs after having executed the Edit-substep. This substep invokes a .NET-call which adds containers and variables to the step context. Are there any special things to consider, when doing this?
(5,252 Views)
Update: I also noticed that when I delete the variables (framed red) added by the Edit-substep I am able to copy the step and can re-open the sequence file:
(5,248 Views)
Accepted by topic author bleiber
I solved the issue by changing the type of the expression-strings from Expression (String) to String.
Now I can copy the step and re-open a sequence file containing it-
(5,244 Views)
Hi bleiber,
is everything working now or did you encounter any other issues?
(5,231 Views)
