NI TestStand
Engine.DisplayMessageBox versus CPU
I noticed that the Engine.DisplayMessageBox is CPU intensive for no reason (one core saturated).
As an example this method is used in the VI Display Error of both Simple and Full-Featured LabVIEW OI.
Sébastien
(1,634 Views)
Any thought of TestStand dev team ?
(1,581 Views)
I am unable to reproduce this issue using TS 2021 in SeqEdit, LV 20.0 and LV-build executable (LV 20.0) . I have also verified that the code in the TestStand engine has not changed to impact behavior since TS 4.0.
Couple of questions:
What version of TestStand and LabVIEW are you using? Are you able to reproduce this issue on multiple machines?
Anand Jain
NI
(1,562 Views)
I use TS 2020 and LV 2020.
The issue is very easy to reproduce by generating a fake error into the state machine of the simple TS OI.
With breakpoints I see my CPU going from 1% to 12% when the error message is displayed, then falling back to 1% afterwards.
(1,524 Views)
