NI TestStand
Dynamically load virtual device (NI-Switch)
Is there a way to dynamically load (import) an NI-Swtich virtual device from disk in either LabVIEW or TestStand?
<cross posted in the LabVIEW forum>
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,815 Views)
Accepted by topic author crelf
Hi crelf,
It is possible to import a saved XML switch configuration file representing a virtual NI-Switch device. You must have Switch Executive installed for your version of LabVIEW. The VI is called “niseCfg Import”, found on the Functions>>Measurement I/O>>Switch Executive>>Configuration palette. You could then call this VI from TestStand to configure your NI-Switch device.
David G
Sales Engineer - SE Michigan & N Ohio
(3,796 Views)
Of course - I was looking in the wrong palette (Switch, not Switch Executive). Thanks DJDaveNI!
(3,781 Views)
