‎03-11-2010 10:43 PM
Hi Ppl
Is there any TestStand API to get the module paths of a DLL adapter type step. I was referring to the teststand help in the following link . But i was not able to locate the correct property. Similarly I also want to get the module paths of ActiveX, Dot Net adapter type steps. I had success in only getting the LabVIEW VI paths using LabVIEWModule.VIPath.
‎03-12-2010 03:41 AM
The module path is a hidden property, so searching for it without enabling "Show Hidden Properties" in the Station Options will make it a little difficult.
Each step has a hidden container called TS where step specific data is stored. The lookup string you are looking for is:
For CVI and C/C++ Adapter: Step.TS.SData.Call.LibPath
For .NET Adapter: Step.TS.SData.Call.AssemblyPath
hope this helps,
Norbert
‎03-12-2010 08:25 AM
You can get the module paths for both DLL and CVI modules by using the CommonCModule API class:
dllModule.AsCommonCModule.ModulePath
For DotNet modules, you use the GetAssembly method. I don't think the ActiveX/COM module stores a path to the COM server.
‎03-12-2010 01:12 PM - edited ‎03-12-2010 01:12 PM
NOTE: Using the API that Erik mentioned is the preferred solution for accessing code module information. We will maintain backwards compatibility for the API whenever possible. Property locations, on the other hand, are more likely to change between versions of TestStand. Thus using the API is more future proof.
-Doug
