NI TestStand
Disable report generation API
Is there any TestStand  API  function  to disable reprort generation?
Message 1 of 8
(4,962 Views)
Have you tried checking the check box "Disable Report Generation" in the Report Options dialog?
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(4,961 Views)
sorry, I want to program to disable report generation  with CVI .
 so i need a TestStand  API function.
no report tab in TestStand.
Message 3 of 8
(4,959 Views)
Do you want to toggle reporting using a custom user interface?
Norbert
Norbert
Expert: Geometry
Message 4 of 8
(4,957 Views)
yes
Message 5 of 8
(4,955 Views)
Accepted by topic author NIRebot
I hope you will this attachement helpful.
Norbert
Norbert
Expert: Geometry
Message 6 of 8
(4,941 Views)
Thanks a lot  .
The example is  very userful.
Message 7 of 8
(4,932 Views)
Hi together,
is there any chance to do this in Teststand in the Tab?
I tried:
Types: MyTypes.ini --> Copy (e.g. Numeric Limit) in it--> Properties --> Edit Substeps
--> Add.. C/C++ DLL Call --> then i tried the EditPassFailStep of the "CommonSubsteps.dll"
But dont work... Smiley Sad, does not know how to use it neither i dont know whether its the right dll to touch...
:womanfrustrated:
Message 8 of 8
(4,564 Views)
