05-30-2011 03:08 AM
Is there any TestStand API function to disable reprort generation?
05-30-2011 03:34 AM
Have you tried checking the check box "Disable Report Generation" in the Report Options dialog?
hope this helps,
Norbert
05-30-2011 03:48 AM
sorry, I want to program to disable report generation with CVI .
so i need a TestStand API function.
no report tab in TestStand.
05-30-2011 03:54 AM
Do you want to toggle reporting using a custom user interface?
Norbert
05-30-2011 03:55 AM
yes
05-30-2011 06:10 AM
I hope you will this attachement helpful.
Norbert
05-30-2011 09:46 AM
Thanks a lot .
The example is very userful.
07-08-2014 10:21 AM
Hi together,
is there any chance to do this in Teststand in the Tab?
I tried:
Types: MyTypes.ini --> Copy (e.g. Numeric Limit) in it--> Properties --> Edit Substeps
--> Add.. C/C++ DLL Call --> then i tried the EditPassFailStep of the "CommonSubsteps.dll"
But dont work...
, does not know how to use it neither i dont know whether its the right dll to touch...
:womanfrustrated:
