NI TestStand
Disable "Break on Step Failure" in a Step
I'm working on a project that in some cases, (i.e.: during startup, shutdown) subsequence steps typically may fail (which is normal).
  Because of these failures make it nearly impossible to set "Break on Step Failure" and stop on the failed step, because there are so many of them.
What I'd like to do is create a set of steps going into some of these startup and shutdown library routines such as:
    Step1: Disable "Break on Step Failure:
       Precondition:  If SeqEdit "Break on Step Failure" = Enabled
       Post Expression: "Break on Step Failure" = Disabled
                                 Locals.bDisableSet = True
    Step2: Enable "Break on Step Failure:
       Precondition:  If Locals.bDisableSet = True
       Post Expression: "Break on Step Failure" = Enabled
                                 Locals.bDisableSet = False
What I need is the commands to test to see if the SeqEdit "Break on Step Failure" is Enabled or Disable, and how to reset the value within the steps.
We're running TestStand 2010
Mike
(6,464 Views)
Accepted by Mikef
You can use this function  :
To read status :
Locals.flag=RunState.Engine.stationoptions.BreakOnStepFailure ( locals.flag is Boolean variable)
To set status :
RunState.Engine.stationoptions.BreakOnStepFailure=False ( or True to enable)
(6,454 Views)
Thanks for the reply,
Looks like this is the solution, however, I've run across a condition that sort of complicates things.
I have some steps such as:
    Read Parameter(x)
      Looping Property is:
         Loop Type: "Pass/Fail count"
         Stop after "1"   Itterations "pass" or after a maximum of "1000"
Basically, it's a step that loops for 1000 itteration or until it Passes.
    BreakOnStepFailure stops on each itteration of "Failed".
Is there a way to disable the "BreakOnStepFailure" within the step, or am I forced to add steps before and after this step?
    I can't change the Post Expression to not "Fail", but is there another STATE that I can look for so that it doesn't report "Failed" until it Passes?
I thought about Disabling the "BreakOnStepFailure" in the PreExpression and Enabling it in the Post Expression, but thats turnign it On and OFF for each itteraition (or at least I think!).
We have a lot of existing steps like this and I'd rather find a solution within the step, rather than having to add steps before and after to disable the "BreakOnStepFailure".  I'm trying to figure out a way to handle these without a lot of re-writing.
Mike
(6,434 Views)
You can check the loop count and enable the flag only after n number of loops in post expression of the looping step.This will avoid breaking of steps for each loop.
RunState.Engine.stationoptions.BreakOnStepFailure=(RunState.LoopIndex<7?False:True)
Hope this helps.
(6,419 Views)
Turns out that I didn't need to worry about the Loop step.  The step will report "Failed" as it's executing, but TestStand won't stop on the failure until it FAILS after completing the Loop option.
The solution above worked GREAT for us.  Thanks.
(6,385 Views)
